Removing RS lower grille?!
Car  A Flamin' Red one
I'm looking at changing the front lower grille to one that has had a pre-cut hole and trumpet, ready for a CAF. How the hell do I remove said grille!? To be fair I've not yet given it a propper look but it would be nice to do it armed with some info :)
It's clipped in, but they're a b*****d to get back on
I think I pried them out with a screwdriver (gently)
Yup, just push it back until all the clips are undone - some usually stiffer than others but you'll get there :)
I've been wanting to go back to a Std Uncut Grill so could do a Swap and a Few Quid my way
PM if your Interested
Ordinarily I would but I'm keeping my original uncut one for the exact reason you want one. I bought the cut grille, trumpet and CAF from another member off here without a swap :)
Just fitted the CAF in my lunch break - how the f**k do you get it down to the lower grille!? It's tighter than a nun's arse with the fan, radiator etc etc in the way! :(
I had to remove part of the plastic panel that sits at a right angle to the bumper, then feed the CAF up towards the back of the headlight :)
