Black-Gold 182
Just a few reasons why the Renault Sport Clio 182 could be one of the best cars ever...
[FONT=Times New Roman,Times][/FONT]
[FONT=Times New Roman,Times]Renault Sport Clio 182[/FONT]
[FONT=Arial,Helvetica][SIZE=+2]R[/SIZE][SIZE=-1]enault Sport Clio 2.0 RS has been proved a thorough success no matter in terms of market reception or press comments. However, the hot Clio does not want to rest on its laurel. It is now evolved into an even better car, Clio 182. The new car is even faster and better to control.[/SIZE][/FONT] [FONT=Arial,Helvetica][SIZE=-1]The new name indicates a maximum horsepower of 182, 10 more than its predecessor. This is achieved mainly by improved breathing - both the new catalytic converter and exhaust manifolds contribute to freer air flow. Maximum torque remains unchanged at 147 lbft but it arrives 150rpm earlier. Anyway, the Renault Sport engine is still considered to be one of the most versatile 2-litre four-cylinder engines in the world. On the one hand, it can rev to 7200rpm without any complaints. On the other hand, 80% of peak torque is available from as low as 2000rpm, thanks to variable valve timing and variable intake manifolds. It is therefore more tractable than the rival engines from Honda and Peugeot. [/SIZE][/FONT]
[FONT=Arial,Helvetica][SIZE=-1]Apart from engine, Clio 182 also received a chassis upgrade. To improve cornering stability, front and rear tracks are widened by 12 and 16mm respectively while wheelbase is extended by 13mm. A 10% increase of front spring stiffness, increased caster angle, revised rear dampers, stiffer anti-roll bars and wider 205 tires also contribute a lot to handling. As a result, the Clio 182 grips better, turns into corners sharper and displays less understeer. Best of all, the fun-playing progressive lift-off oversteer is still there. Surprisingly, the Clio’s fine ride quality is almost unaffected, thanks to the well-judged damper setup. This chassis modification is highly successful. [/SIZE][/FONT]
