Rob's F4R'd Dynamique Track Car
david hodson
If the cheap ones are un scewing sound like slack made threads
also use bearing fit and not threadlock as it goes off better
but then if you need to get them out you will need to heat them up .
  BMW E36 328
This is the first set of studs that i will have used. Never used any other type of stud. Just went for the pressed in studs as i didnt want to be messing about/ worrying about anything coming loose :)
