Ooohhh.. ouch.
CS whipround ?
CS whipround ?
Is this not finished yet ?
:rasp:
Excellent!
How is running the shaft to the rear differential going to affect the cabin of the Clio? I gather you'll need a fair bit of clearance so its fairly high from the deck?
Oh, I see.. the excuses are here already.
Hmmmm, me thinks Pug 205 t16. Shouldn't you put the engine in the back though?![]()
Good luck, following closely! On a smaller note, my businees partner does the odd 12 car, and apparently spotlights are banned??? Whats the score there? or is it just different clubs?
Fantastic project!!
One tip from me, once the engine is and bolted into the bay, double check to make sure you there is enough room to remove the coilpacks on each side and have enough space to access the plugs
Thanks for that, vitally important. I've changed plus on Scoobys before!
is it the rear axle botls on the clio spining?? if so if you lift the rear seat base youll see 3 silver round bolt heads with brackets, grip with vices get some one to buzz should come off.
interesting build look forward to seeing it complete.
