Rubbage
Ive recently put some 17s on my Dynamique and when Im on my own in the car it doesnt rub 2 much when it goes over dips in the road, when Ive other people in it however, it does.
Has n e 1 else had this prob? I was thinking of changing the suspension on it 2 make it stiffer but Im not sure whether this will help the problem.
N e 1 got n e advice?
  Lionel Richie
Is it lowered????? Sounds like youve got the wrong offset there mate!!!
Mine "was" lowered 60mm on 17s and it didnt rub with a full car
Nah its not lowered, I woulda thought though that they woulda made sure when they gave me the tyres they were the right offset, didnt think Id have 2 remind them 2 make sure they would b the right 1s.
Ive only had them about a week, u reckon the shop will change them 4 me?
  Renault Laguna Sports
As others have said with the correct offset you can get away with a 60 mm drop and still carry a full car load. Not sure of the offset, think its et 36, tyres should be 205/40x17.
  Lionel Richie
The offset is stamped on the back of the wheel somewhere, usually either in the centre of the wheel or on the rim
What make/model are the wheels???? Are they 7inches wide or 7.5????? if theyre 7.5 then thatll explain the problem!!!! 7.5 is TOO wide!!!!!
I took a wheel off 2day and they r 7x17, offset is 40, gave the bloke a ring where I got them from and he said that they should still b ok.
  Lionel Richie
Should be ok with et40!!!!! wheres it catching???? FRONT or REAR??? BOTH sides????
mines lowered 60mm on 17s and havent had a prob with 4 pplz in the car!
sounds like wrong offset!
I had probs fitting mine to start off with as the alloys were hitting the calipers so i thought i had the wrong ones! but the silly idiots at the company forgot to give me spiggot rings!!
From what I can tell it is mainly on the back, havent looked properly at the front though,hopefully all will get sorted on Sat, fingers crossed.
