The aircon is a smart unit that will automatically disengage itself during startup, then engage again a few secs later....but turning it off helps, nice one GR!
And the rough cold idle IS, no buts, maybes or IFs, due to EURO3 emmisions compliance. Fact is your catalytic coverter uses heat to change the composition of the waste gasses, when u start it from cold, the cat doesnt work, it doesnt do anything for emmisions. And EURO 3 law is exactly the same emmisions levels as EURO 2 but WITHOUT the 5 minute warmup period. This is why the engine has to run lean (to meet the emmisions from the off) and rough for till its warmed the cat up to do its job. This is also why the MK2 has a single cat and not a twin item like the MK1 as it warms faster, its also why they have the second lambda.
Fuel, pluh or anything else wont help solve it........just use full throttle when you leave your rd, only up to about 3500rpm, itll warm up faster and before anybody says it, its not bad for the engine no.
