Safety devices help
alexapps
Car  172 RaceCar, VW-T5
Hey all,
I mocked up the cage in the car today to see how it all fits together.
I'm not really sure how I should mount the rear feet of the cage though, I'm hoping to race I'm tarc production series this year so I need to ensure the car complies with the msa blue book.
Does this plate (in the picture) sit outside the car? Or do I need to open up the holes to allow the captive nuts to pass through and then get my welder to weld this plate to the arch?
Thanks in advance for the help!
-Alex
image by alexanderrobertjames, on Flickr
The more I think about this, it makes more sense in my head that this plate sits in the wheel arch and the plate on the cage leg just fits onto the shell so it's like this (cage | shell | plate).
Anyone know?
Great thanks :)
so there is no spreader plate that sits between the cage and shell?
and I'm guessing that plate doesn't need welding in the wheel arch?
Alex
No spreader plate, as you say it is the cage foot then the wheel arch and then the fixing plate inside the arch with the nuts towards the wheel.
The feet on the cage will form to the arch shape when tightened up.
Awesome, thanks for the clarification both :)
Easier than I thought for some reason.
-Alex
Wouldn't you usually have the bolt head in the wheel arch and the nut on the inside of the car so any excess thread from the bolt is on the inside of the car and not sticking out in the arch.
I did think that, but with these plates I can't see how you could.
i guess you could run the bolt through the captive nut first and stick a nyloc on the inside but that defeats the point of the captive nut...
If you cut the bolt down to size so it's flush to the captive nut once tightened you'd have no extra thread to catch the tyre. It would be exactly the same amount protruding as the nut
Sometimes scrutineers get funny about the thread being flush, but you could just put some weld on the end? This would stop it coming undone then
Just my thoughts :)
