Evo 5 RS
Yawn.
I thought usual unleaded was 95 Ron, V-power from BP was 97 Ron and the Tesco high octane one was 99 Ron.
102 apparently.
Bp is ultimate, which is 97 but vpower is shell which is 99 RonI thought usual unleaded was 95 Ron, V-power from BP was 97 Ron and the Tesco high octane one was 99 Ron.
Normal petrol is 95 majority of the tome here. Bp ultimate is 97 and tesco momentum is 99
Tesco has more ethanol in it, good for RON number but bad for calorific value.
That was bp ultimate 102 which then made available close to racing circuits, I never saw it personally, not sure if it even still exists.
we used to buy our 102 from the BP in egham which isn't near a race circuit ?
BP102 is not around in the uk any more , but thats because the MSA blue book has everything running on regular pump fuel now so no need to sell it as it was a loophole for pump fuel because x amount of stations sold it .
F1 has run on standard octane fuel and cannot contain additives not in regular pump fuel for some years , not like back in the 80's when fuel burnt your nostrils.
Closest track is Longcross. I wouldn't be surprised if it had anything to do with the 2x Ferrari dealers there!
No idea what calorific value is if I'm being honest chip lol.
People often think the RON value is how potent or strong the fuel is, it isnt, and in the case of the tesco stuff its higher RON but actually a weaker fuel.
Or the RON is, is just a measure of det resistance, nothing else at all.
Unless you are high boost or very high comp, a mega high RON fuel is of little or not use, and even if you are then you need a remap to make use of it.
Would MON be a more useful number to use as it's a better representation of the performance of the fuel.
With it being tested under more load at a higher rpm and at different ignition timings?
Its still only a measure of knock resistance though, rather than of fuel strength, so a higher MON fuel can still need to be run richer than a lower one (E85 for example) so can be bad for economy.
Then we get into adding oxygen in race fuels .... again needing to map/jet rich ... gains power to a point then tails off
Again no gain in ron rating
Sure it was Shell at the time, they sell Gulf 102 now though.That was bp ultimate 102 which then made available close to racing circuits, I never saw it personally, not sure if it even still exists.
those glasses were out years ago
Chip, some cars definately need higher octane fuel though right? Mine, my dads and mates Honda's never seemed to run right unless it was optimax (other fuels available). I do know there pump fuel is top stuff over there.
The 350z lads are positive your there engines will die if they use standard unleaded.
T
