Snow Foam
Car  RS Clio 182
I recently got some snow foam from cleanyourcar.com and a detergent bottle for my halfords pressure washer. When i tried it there wasnt that much foam, it seems that not enough pressure was passing through the detergent bottles head to make a good heavy layer of foam even with double the dosage suggested on the bottle.
Can anyone suggest a good/cheap foam lance that i can use? Any tips more then welcome
Is it the bosche type adapter for a halfords pressure washer it looks like the bayonet type fitment? Pretty steep price but if its good then i may have to save up some pennys :)
Im fairly sure for halfords washers its the Kew/Alto fitting, but I cant find my invoice to check for sure. Its fairly obvious if you get the fitting and compare it to the pictures on the CYC website.
I use this one (using the same foam in the auction)
http://cgi.ebay.co.uk/HD-FOAM-LANCE...arts_Vehicles_CarParts_SM&hash=item5ad958ade8
with my Karcher 2.15 pressure washer, its not an expensive washer but certainly works a treat...
