spacers
Car  www.renparts.co.uk
Looking on here at a set of 25mm ones as the last company gave me a refund after not been delivered for 2 months
http://www.performancefx.net/wsrenault.htm
choice of material is alloy or steel?
which do i go for, there is a 20 quid difference in price and if you don't know how these type work they bolt to the hub and the wheel to the spacer. Im a lil bit worried if with the alloy ones im likely to thread them or they won't be strong enough. or will the steel ones be too heavy?
thanks
josh
Dave3141 said:
Have sh*t if you're worried about the weight of them.
yeh but its different when its rolling weight is it not? its going to be exadurated somewhat?
PS: bring rooney on to kick some portugese ass!
russ9898 said:
just get some from ebay mate lol only cost you about £16 for all 4
lol you kids never learn. Theye hubcentrics with spiggot rings attached. not shitty universal spacers that feel like ur driving a black dildo ;)
I wouldn't get 25mm spacers unless your offset is realy messed up 10mm at most.
Weight won't matter though unless your realy into cars in which case you'd have spent a load of suspension parts and wouldn't be able to run 25mm hubs.
What i actually wanted to do was run 172 wishbones, or is it the hub carrers? as i figured it would space it correctly? am i correct in thinking this? Like i said ive already got 20mm spacers and have noticed no detrimental effects. Think ill go for the 25mm steel ones.
16v_jon said:
hub carriers on 172 give it that bit more track the wishbones are the same lenth
If i ran the hub carriers would i need the driveshafts as well, basically if i bought the hub carriers and driveshafts would that be complete?
thanks
josh
