spacers
  BMW E36 328
im having a bit of trouble findin either 10 or 15mm hubcentric
ive looked on venom motor sport and deamon tweeks and they both only supply spacers with longer wheel bolts
System (A) - Supplied as a flat spacer
does anyone know where i can get them from? or do i just have to use longer wheel bolts because i would prefer hubcentric
thanks rob
  AMV8, Mk1 Golf
you wont get less than 15mm in the bolt on tyre as they arnt thick enough to allow the room for the bolt heads in the spacer,
Hubcentric and Type A spacers mean two different things btw, I'm reading it like you think they are the same.
Hubcentric are for bigger spacers, they have a hubcentric lip to help locate the wheel.
Type A means they use longer bolts (can be hubcentric).
Type B means they bolt onto your hub, then the wheel onto them, they are generally all hubcentric.
IIRC you can't get smaller than 20mm if you are after type B spacers.
And the smallest hubcentric spacers you can get are 13mm (Type A though), from FK, I think they may even do 10mm hubcentric.
EDIT: FK do 15mm a side huncentric type B spacers!
http://www.fk-automotive.de/websale7/FK-Wheel-spacer---30-mm-System-B---fit-for.htm?Ctx={ver/7/ver}{st/3eb/st}{cmd/0/cmd}{m/websale/m}{s/fk-automotive/s}{l/English/l}{mi/199-2834/mi}{pi/1510189/pi}{po/1/po}{fc/x/fc}{p1/d87563bdc63d3db053173e873af7625c/p1}{md5/6523bfee8d7ade2b289244f8fa5ef5ed/md5}
  BMW E36 328
ahh ryt im defo going to have another look, i would have thought venom motorsport would have sold them gona ring them up instead :D
