Spraying alloys help
Car  172 SPORT PH2
http://www.carplan.co.uk/index.cfm?product=264
http://www.carplan.co.uk/index.cfm?product=262
Far as i can tell the first one is dedicated to like plastic trims possibly
and the second one is more for like alloys wheels ?
Or the first one is only one available in silver, whereas the second on isnt if you check colour availability..
Also will this body filler be ok to use to refurb my alloys ??
http://cgi.ebay.co.uk/Plastic-Paddi...293902&cguid=72ef1d5912e0a0a9ef25e125ffe9d5f4
will this work pls??
Also the things i will be buying are
3 cans of paint
2 cans of clear laquer
3 cans of primer
pack of 240 grade wet / dry sand paper
pack of 1200 grade wet/dry sand paper
1-2 rolls of masking tape
Are these what im looking at , what i need
list sounds about right, just maybe some 600grit aswell, make sure you sand them all down with 240, 600 and then 1200 to get a good finsh. Then a few coats of primer, leave to dry tilll rock solid. Then a few coats of paint, leave to dry. And then 1 or 2 coats of laquer dependent on finish wanted and then leave that to dry for at least 24 hours. always do the spraying somewhere warm. hope this helps, what i did with my old alloys
