Starting problem solved but a new one appears.
Car  Clio 172 Sport
Ok, tried starting the car again after work tonight following the advice I got but no joy. Popped open the bonnet, checked connections and checked the fuses/relays were ok and sat correctly.
Car fired up straight away. Only problem now is, as soon as the car starts, my headlights come on. Turn car off, headlights go out.
Was getting dark when I sorted things so couldn't see very well but is there an earth near the fuse box under the bonnet and could that be causing this new issue?
Turn ignition key so the dash lights come on but not started, then turn the headlights on and off twice. You should hear a beep if it has worked.
Youre a star. Worked. You can have the use of my wife for a night as a thankyou. :hail:
