well, the only true way to power is doing head work.....the more air you can flow, the more fuel you can add....
so, i would go for the twister as a starter, exhaust is importnat, but only when the std one becomes a restriciton. and i doubt the top exhaust gave 8bhp!!!! haha! no way.
but decent system is a must. i would research and see what the most restrictive part of your engine is, then work on that. a simple cahnge to 1 choke poer cylinder could yeild a decent amount of torque and top end power. but everything you do from now on WILL be expensive.
i can port heads for 20 quid a port....i dont polish the inlets because it is detrimental to fuel suspension and fuel consilidation on port walls as the inertial force of the fuel actually takes it out of the air flow and it collects on the walls.
i can port the exhaust ports....but itll only give a few bhp (2) at max rpm and when the engine is fully prepped.
Ching@iamwasted.com
i will be back in the UK in october if you are interested.
