Suspension Turrent bolt
Car  Astra 1.9Cdti SRi
Hey guys,
right the gearbox mount underneath the battery has 3bolts to hold it on, 2 that go into the bottom part of the car and one onto the suspension turrent underneath the fusebox holder..
Mines snapped :(
how do i get it out ? iv tried a normal drill and that didnt make one mark on the bolt, i can see abit of the bolt inside the wheel arch but not enough to get hold of it
whats the best option to get it out asap?
Ouch.
Where's it snapped? At the head?
Can you get the mount off so you've got some room, or is it holding it on?
there bolt is about 2inches long in total and just less than a inch is left in the hole, didnt realise at the time until i went to fit the new mount..
Mount is allready off dude, just i need this out and iv tried to drill it just aint doing :(
theres not enough to get hold on if you get me, theres like 3thread sticking out,
how about drilling straight through it with a big heavy duty drill, should then try and force a big screwdriver in :S
im just stuck for ideas, mechanic said take it to him to get tapped out but car cant move lol
There called bolt extractors, they are a reverse threaded screw like tool that winds into the pre drilled hole in the stuck bolt, and then when tight enough will unwind the stuck bolt.
iv just had a look on ebay, and i think iv seen them around the house somewhere, il go on the hunt now :)
Can you get a junior hack saw on it and cut a slot in it? If so apply some heat and use a large flat head
Thats good thinkin powey, il try that when i go down tommorow, i was hopeing to get the engine in this weekend :( but looks like it wont happen Ffs
