swapping over clio 16v engine advise please
basically engine broike on me every thing siezed and locked up brought new engine to drop straight in.am i correct in saying to do it this way
1st remove exhaust
2nd remove drive shafts
3rd remove plumbing
4th remove electricals
5th remove mounts
6the craine out
7th swap loom over on to new engine
8th do steps 6-1 back to front?
if any body has any helpful advice on doing this as this will be my first time doing it.
cheers
Get a Haynes manual realy but.
to take the drive shafts out you have to drain the gearbox.
No need to remove the who exhaust just disconnect the exhaust manifold under the car.
If you've a crane best take engine and box out as one.
Change the clutch and cambelt whilst your swopping engines.
