Switched ignition live feed
Donny_Dog
Car  Jim's rejects
I've noted about 3 things (gauges mainly) using scotch locks from the cigarette lighter wire!
Sad thing is, I need to add other things into a similar feed, but want to do it correctly.
What is the best way to either share 1 connection with 3 devices safely? do I have to run individual feeds?
Something like this? Not seen any on any UK websites, but my searching has been poor.
How have you done it?
Personally if you're using the cigarette lighter feed for things which are reasonably high loads, I would run a half decent gauge cable from the battery terminal into a relay - use the lighter feed as your 'switch' on the relay and then on the output of the relay, have a set of terminal blocks or something like that to distribute the power
