Sorry people but this cusco kid is really annoying ^^ that does not mean im fire proof that means you dont know italian.as they say in italy intercourseium jecobis meassis asbestossis means F**K YOU JACK I AM FIREPPROOF byeeeeeeeeeeeeeeeeeeeeeeeeee
"vaffunculo prova del fuoco della presa im" is f**k you jack im fire proof.
When i first read this thread i was genuinly intrestd like many others but like some one has pointd out this guy/girl has only come on here to sell an people have gave there opions on it which has not been upto scratch of what cusco wanted, I was going to ask for a small sample for a mate to try out on my car (i have it valet'd) an if it came out good results pictures and info would be posted on here an also if he said it was worth it i would have purchased a big tin/tub/bottle of this for myself.
BUT just from the sheer abuse that he has been giving people on this forum to some of the members such as Rich who people look upto when it comes to cleaning a car or general advice, i personally hope that you dont sell a single item on this forum an as soon as i find out the name of your product ill name and shame it on other forums making sure as much as possible that you struggle to shift it all.
Really my friend you do need to think about how you come across to people.
hi m8 i think you will find this product is made and manufactured by du-pont geoLook at question 2: http://www.gliptone.com/faq.asp
And there's a lot of chat here: http://www.finishing.com/152/28.shtml but a couple of posts stand out:
I stumbled onto this site looking into the entire teflon thing. I think I should clear somethings up. I worked in the fuel cell industry, and we used liquid teflon for its hydrophilic properties. The one poster was correct that when teflon gets hot it can be toxic, but there is no way that can happen on a cars surface. The sintering temperature (the point where teflon melts and adheres to a surface)is 572 degrees f. Teflon in liquid form is a suspended particle and looks milky white.Teflon is actually a particle, and not a liquid.
Teflon can be suspended in a medium (in this case its a wax), to change the properties of the wax. Once the wax wears off, so does the teflon.
Teflon in carpets etc is applied when the cloth is manufactured. That too will wear off in time (scotchguard etc). When its applied to cloth, it is in a less hostile environment then a carpet or a chair.
And
Ok guys, I think I can answer all these questions with the truth and with logic. Manufacturers started adding "TEFLON" to car polish because consumers are familiar with the "word". Nothing will stick to teflon, so its virtually impossible to get it to stick to the finish, UNLESS you physically (mechanically) bond it to the paint the same way they "bond" it to a frying pad. They "scratch" the metal with 1000's of microfine scratches, and then force the pure "PTFE" or (TEFLON-Duponts brand name)into the scratches under head and pressure. Can you do this to your car? Probably, but you probably don't want to scratch the finish to do it, and you don't *have* to, to have a slippery coating. Someone said they could do it, by using a high speed buffer- problem with this, is that if it was truly 100% teflon, the buffing wheel wouldn't cause friction to create the heat (remember its TEFLON-no friction). + or - charges? Electro-magnetically bonding something to your paint finish would hold about as well as rubbing a balloon with wool, and sticking styrofoam to it. By the way, the product that someone claimed was being "manufactured and sold BY DUPONT", isn't a "DUPONT" product, its an outside company, buying TEFLON from DUPONT, licensed to use the DUPONT logo... its not actually made by DUPONT. Look at the company name on the rear of the products. Its not Dupont. That doesn't mean its not a good product, but its not necessary to fool people into buying good products with names like "TEFLON", its just *easier* to do so.
You probably could get a car properly Teflon coated but it would be expensive!
hi m8 i did not start it i just fired back the the aggro regards geoSorry people but this cusco kid is really annoying ^^ that does not mean im fire proof that means you dont know italian.
i said i'd try it, but haven't had a reply from cusco yet. really would like to try it as i have life that doesn't really allow me time to spend a full day fondling my car
Is a joke, you cant take things so serious you need to chill out m8
And
If it's made by DuPont then it's from this range: http://www.carcare.dupont.com/products/products_default.asp
i thought his name was geo?!
geo is my name short for george all my mates call me geo
Out of interest, why do you write it in at the end of each post?
cusco have you got any tins of the stuff in yet? waiting to try it out, so i've not washed the car this weekend to have a good go at it.
