Testing Coilovers
MrBlonde
Sorry if it's been covered,but i didnt have any luck finding anything.How do you check a 2nd hand set of coilovers are ok?.i know obvs is leaks,but what else?.good set to ie Gaz etc
Visual check. And if you can compress the dampers by hand, make the all the rates are the same, the move smoothly, and not too easily.
I can see no leaks and one of them has been reconditioned and thats the one im questioning about as when i push the damper down it does not return?
These are a set of Gaz Gha coilovers,rears are all one piece rather than separate damper and springs.
I Keep hearing mixed views,as some say its fine others say its not.Its had recent refurbish tho and from a fella who deals with Gaz has said it should be fine.
