Rojer
		You running a 240mm rad right? Usually it will come with 8 long screws and 8 short screws. The long ones can either just attach fans, or go through the case and fan as well to mount the radiator (sandwiching the fans between the radiator and case). The short ones are just to mount the radiator to the case if you have your fans on the other side.
If it's fouling on the heatsink you can try putting the fans on the bottom of the radiator instead of on top, that might give you more clearance. Or mount the radiator at the front of your case and use it as an intake, like this.
Anyway, take a photo of your rig and post it so it's clearer what the issue is 👍🏻
Shouldn't you have the top of the rad above the CPU? I would say flip it 180 degrees.
I have had a really annoying fan or some kind of resonance since I built the pc tbh, but it's getting really annoying now. I was going to swap the fans to daisy chain ones, but I don't think you can control each individual fan speed when they are linked. I think my problem comes from running all the fans at the same speed. I recommend watching this video, I'm going to give it a try later and see if that sorts it.
