Mark and Jesus need to get a room ..soooo much love there.. lol
sounds like you actually got all the parts you paid for, I never did, this is 3-4 years on now... I take it you had a happy conclusion to your initial problems?
Yes, I fixed it myself.
fuel consumption
idle control
cold start
Some simple modifications to the fuelling and spark maps sorted them out. When I spoke to Andy a few months ago he was still trying to fob me off with the OMEX hardware fault. Apparently these problems were nothing to do with the mapping.
For the idle problem he wanted to fit an air bypass valve. I had a go at it myself one Sunday morning. The OMEX adds or takes away advance to acheive an idle setpoint. If you want it to idle at 1100rpm it monitors the revs and adds advance it it goes below and takes it away if it goes above. You can monitor a graph that shows rpm vs ignition. My car was sitting at 900rpm always adding advance but never acheiving the setpoint because the rpm was already to low. By increasing the advance in the static map at idle rpm I got a perfectly stable idle.
By using my common sense I acheived something that Andy had tried numerous times to sort but couldnt. I remember going to GDI and describing this problem for the first time to Andy. He rushed out with an allen key and wound the stop on the throttle body. If he new anything about mapping a car he probably would have realised that the idle is based on the throttle position so by winding the throttle body increased the TPS feedback and the OMEX thinks you have the throttle pressed so does not try to idle. Another disaster where the car left worse then it had arrived.
It appears that I am more knowledgeable then Andy when it comes to getting a car to idle using this method. Maybe I could set myself up as an approved OMEX mapper. Read this post would you believe I knew what I was on about?![]()
It's a bit confusing, Mark. You spent 4k on TB conversion at GDI. In the modded clio sticky you seemed quite happy apart from cold start/idle issues.
If you have sorted these out and your clio is now running ok, why are you spending another wedge on basically the same mod? I know folks are being a bit silly and coy about the new induction kit from Angelworks, but can it really be much better than what already exists?
I think the main interest is in why it's taking so long. Sounds interesting but it will be a massive waste of time if it's no better than the current Jenvey setup and still has to lose the aircon... time will tell though
yea but they smell like old men inside![]()
lol at some of the posts.
better off just binnin ur t/b 1*2s and gettin a williams, with bodies...hehe.
could buy the car, and get the mods done for less than u all seem to be paying for bodies on yours, and will end up with a faster car, that handles better, and looks better.
and you end up with something similar to this
http://youtube.com/watch?v=VKh7TZ7GlyU
some people never listen to good reason![]()
hmmm... looks better? - agree
handles better? - agree
goes better? - jury is out, yours stripped out still aint got the minerals![]()
aye ..but its nowhere near finished yet.
anybody interested in bodies needs to wait till Jan, there will be some exciting new developments
shhhhh
shhhhh
Which jan pal?only messing around but how is this kit coming along, is it any closer to the finished product?
are there people off here carless whilst this is being developed? cant be arsed to read all the thread again, but i thought some people had put there cars forward for the developement of the kit? can any of you comment?
