Yeah I'm happy to help out if I can mate.
Thanks, hoping it's covered as it was 6th gear that was replaced but I'll let you know.
Tim I can't believe you had the wheels off and faffed around with the breakers and you didn't clean the calipers it paint the centre of the discs!!
Shane about 6th gear but then it wouldn't be your car if it remained reliable would it! X
Shame about the gearbox, AGAIN!![]()
My little brother has a forged R26 and he had exactly the problem with sixth. Luckily I still had the clusters out of an ND0 020 from when I'd took the LSD out. It should be an easy fix.
Wow some money pumped into this!!
Nice update
Fair play for seeing all this work through, you must have the patience of a saint.
I remember speaking to you at Bedford earlier in the year, not long after you had got the car back from its first rebuild. I had a black R26 at the time, and I ended up putting a rod through the block at the next trackday that I did after Bedford. I thought about getting a forged lump / better turbo, but instead I cut my losses and sold that for spares/repairs and got another 172 track car!
And I thought I had a expensive month!
I'd say the damage to the bearings and everything else in the box came from the 6th gear failure mate.
Has it got an input shaft shim fitted?! :wink:
That'll be from all the s**t that's passed through it.One of the bearings was damaged but rest were described as noisy/sandy feeling.
Fletch mentioned your diagnosis, hope it's all coming back together ok.
Glad to see this coming together, really feel for you with all the issues you've had.
Out of interest what sort of money did the box rebuild set you back? Mine is making noises on my MK3 RS and they havnt got worse but I'll probably get it rebuilt sooner rather than later so looking for a good solid place to send it to
I had the exact same problem with my Megane with the hub bearing inserts. Mine were pretty badly corroded and it was causing a fair bit of play in the hub.
2 new inserts, grease bolts & new bearings and it feels better than ever.
Where did you get the powerflex inserts from?
Flippin heck Tim, this still an ongoing saga?
Carbon dipped?
Yellow and Red works well, But then i am bias :wink:
You still not fancy some R26R wheels? Or has the wallet taken a big enough kicking this/last year? You bringing it along at the end of the month?
Long time no speak mate :smile:
Great build, I've seen bits hear and there, but reading it all took me a while! Amazing stuff.
Just read the entire thread.
Bravo for persisting with it!!
:up:
