I might be selling the R26 as I’m buying a house and girlfriend is due in May.
How much do you think I should advertise it for? PM me if you want to make an offer.
Car is on 143k miles and spec is below:
Engine (original engine rebuilt by RS Tuning in August 2015)
- 83mm CP Carillo pistons
- Manley rods
- ACL big end bearings
- Catcams cams
- Supertech valves
- Supertech double spring kit
- 630cc injectors
- RS Tuning Megane 250 hybrid turbo
- Forge recirc value and actuator
- ITG induction kit with larger ITG filter
- Forge intercooler
- Forge hard pipe kit
- Forge coolant hoses
- Mocal oil catch can
- Varley 25 battery
- Powdercoated lower arms, are, inlet manifold, engine mount, oil breather plate and brackets
- Ktec 3" exhaust
- Mapped by RS Tuning 329.9bhp and 360lbft
Transmission
- R26 gearbox refurbished in September 2016
- RS Tuning SMF
- R26.r clutch
Handling
- Cooksport lowering springs
- R26 dampers and topmounts
- Poweflex lower arm and ARB bushes
- Powerflex engine mount bushes
- Ktec stud conversion kit
- PMS spacers 10mm front and 18mm rear
- R26 anthracite alloys with AD08R tyres
- R26 red alloys with R888R tyres
Braking
- Ferodo DS2500 front pads
- Brembo HC front discs
- OEM rear pads
- Renault rear discs
- Goodridge brake hoses
- ATE brake fluid
Interior and Exterior
- GoPro mount above radio display
- Scanguage II
- AEM AFR gauge
- Recaro seat base carbon build no. decals
- R26.r spoiler in LY
- MEGANE badge delete
- Manley rods
- Catcams cams
- Supertech valves
- 630cc injectors
- Forge intercooler
- Varley 25 battery
- Ktec 3" exhaust
Transmission
- RS Tuning SMF
- R26.r clutch
Handling
Braking
- OEM rear pads
- ATE brake fluid
- Scanguage II
- AEM AFR gauge
