Topping up coolant level
  306 GTI-6
Is it ok to buy some engine coolant from halfords and top up the level?
Just i had a look at it and it said on the bottle to drain and flush the system first, as using mixed manufacturers coolant isnt advisable.
Do i have to flush the system? or can i just whack some in?
  Clio v6
What what I've read Halfords antifreeze is gycol based so mixing it with Renault antifreeze should be ok.
  306 GTI-6
its just above min, just giving it a quick check as winter is setting in, though tuesday night was a very warm 13degC!
  BMW M135i
If its only that ammount you'll be fine to just top it up with water, it's only going to be 500ml at the absolute most.
