Tramlining and torquesteer
  Clio 182
My 182 seems to be tramlining quite badly to the right, it tries to pull itself to the other side of the road if you get near the white lines. Also the otherday I gave it a bootfull in first gear and it torqued steered quite violently to the right again I assume it was tramlining and it got exaggerated as I booted it.
It has had a right hand trackrod end, steering rack bushes and alignment lately and the wishbone bushes and balljoints have no play, apart from tramlining it drives very nicely. From what I can tell it only does it to the right, or it is certainly much worse going right. The tyres are half worn Goodyear Eagles F1's so I doubt it's them.
Anyone got any idea's?
sburrell93
Scotland - South
Inner ones can go but if there's no play they shouldn't be a problem.
I'm at a loss if the alignment is correct. Only thing I can think is that its driveshaft related, with uneven power going to each wheel. Not sure what would cause it though.
  182, SQ7, Trafic
Ah yes, this will help with the tramlining at 50mph with a small throttle application.
As I said, the track rods being replaced at the same time probably will
You booted it in first gear at 50mph? What gearbox are you running?
  182, SQ7, Trafic
Power only goes to one wheel at once, you know that right?
  182, SQ7, Trafic
Uneven power isn't a thing, if it was it would pull to the side all the time as only one wheel puts power down, unless you have a limited slip differential.
lee M4RSH
I get this tramlining too.
I'm in need of new tyres so I put it down to that. Let me know if you find out it was something not mentioned.
  182, SQ7, Trafic
Uneven power isn't a thing with cars with a standard differential.
If one wheel has a lighter load then power goes to that wheel.
I don't see you correlation between uneven power and uneven length driveshafts though.
sburrell93
Scotland - South
That's pretty much exactly what I was meaning. Its still uneven power distribution in a way.
Uneven length driveshafts will always give torque steer (in something with a bit more than a Clio anyway lol) with the power taking the path of least resistance, or the shorter one. Without the initial uneven power there, torque steer wouldn't happen. That was my thinking anyway.
  Clio 182
The other trackrod had no play in granted it's not brand new but its hardly going to have enough effect to make the car do what it's doing.
You implied that the torque steer issues were due to poor throttle control which from a standstill in 1st or at 50mph in 5th is not case as you yourself have said that you won't get torque steer in a Clio, so the fact that I got torquesteer implies something is wrong, perhaps I am misusing the statement torquesteer as it was the tramlining causing the wheel to turn but it is the same phenomenon.
I assume he is meaning torque but as power is a function or Torque it's not that innaccurate. Unequal driveshafts are the main cause of torquesteer in front wheel drive cars.
Anyway to my problem, I feel the best and easiest place to start is to get the tracking rechecked at a different place as sburrell has said other than tracking he is at a loss.
  182, SQ7, Trafic
Every Clio has uneven driveshafts though and none suffer from torque steer. Even my 250bhp one was fine.
Something as little as an old TRE can cause issues especially if one side has been changed. Putting on a newer part one side will highlight problems on the other side.
I'd be replacing them and the ball joints first then getting the alignment sorted.
  Clio 182
Mine did this last month or so ago and it was the wheel bearing up front. Have you checked that for play?
Interesting I have notice a drone that I think might be a wheel bearing on the way out but it sounded like it was coming from the rear, I will have a check and see if there is any play this weekend was it easy to spot the play in yours?
  phase 1 172
have you checked the springs to see if a small section has snapped off / strut top mounts for excessive play?
if theres play in any of the joints the alignment you had done is likely to not be right
Dicky Belly 3
Yes mate, very easy. Life the car up and check for play in the disk holding the wheel at quarter to three and rocking back and forth.
  182, SQ7, Trafic
What, 1WD?
Well no, as it has two wheels that drive, like 4wd, it's usually only 2wd on most newer vehicles.
A differential works by putting power to wheel with the least traction, where you would use a limited slip differential to have power going to both wheels.
That's a proper s**t explanation but it's basically correct.
Ol’ Tarby
  Clio 220 Trophy
But what if both wheels have an even amount of traction?
Power goes to both wheels, its just when one breaks traction, all the power will then go to that one wheel
Dicky Belly 3
WAT
A differential puts power to both wheels unless it doesn't have any traction then all the power goes to the wheel that has lost that traction. Unless you have an LSD.
Edit - Beaten to it by james lol
