Turbo project!!!
Shut it hudson!! no joke, mine is just bolted together and taped up at present!! :)
Apparently i have to improve it though!:S
I hope you've used pleanty of tape and secured it properly. If the tape ever wore awa and that connector earthed onto the body you'd have a very quick bonfire!
Had it go though the tape first time lol lucky it just blows the fuse on mine. Rapped up very well this time ;)
Boost has been turned up again :) 1.1 bar now need to put the car on the rollers see what its putting out.
Ryan you are lucky i guessed a safe setup for more boost! Playing with fire (hot enough to melt some holes ;) ) upping the boost without checking it PROPERLY
Need to go yours soon as i can to sort cold start out
Kev you have been told!!!! That BM connector block looks like what we need!!!!
You run a fuse on the main engine live? What size fuse is it? I guess the starter motor has a seperate live?
only got the standard one in but it had blown last time it earthed out on car wont do it again anyway iv rapped it up loads better
Is ur plate something like LS04...If so just watched a couple of vids of this on youtube, that turbo sounds absolutely mental!:evil: nice work
Ye it is mate lol got a few on there that people have put up had a few people film me.:)
Sounds really menacing that turbo, sorry havent really followed the thread much, what bhp u running there? quality project:o
i can not believe you went and upped the boost with out mapping it, as pmurraydid you a safe map you are fine this time but keep doing things like that and you WILL end up needing yet another engine
Ive got a AFR gauge on car to show what its doing its not going up anymore till its been sorted. Cold start is not good at the min.
Pleased at the min i checked everything on the car before and there are no problems gear bout is starting to go.
Going in for the mapped to be tweaked tomorrow :) Get some figures too see the power its putting out.
once rolling this should be a monster!!
good read. looked and sounded the b****cks at the B'ham meet in November!
respect for taking it all on yourself also!!
Just had a bit of a play on the way back from RS tuning then...
It was the same speed as an Alfa 147 GTA upto 130ish on the private runway.......I rekon it would have pulled on ryans though with them having 6 gears tbh....
Not bad tbh im running same power as one with 2 people in car and boot full of stuff.
