stevo172-RWD
clio 172 rwd
why not just ditch the canister and the pipe? less clutter and even tidier
That what iv done too!
No its just a normal pipeNever had that problem removing mine.
Has yours got a oneway valve on the pipe?
not quite the same though mate lolol, you put the engine 9 feet furthur back
Ye thats causing it to spool bit slowerSo boost pressure goes to the canistor?
when you block the pipe it just stalls. If i did that wouldnt it be the same as if i had no pipe at allYou could take it off
Mybe block pipe that goes to manifold.
Remove the top of the canistor and leave the sensor plugged in?
What do you say danny?
Whats the reason for that??oh dear, it's relying on an air leak for idle air. start the map again
1000 about longer the pipe the lower the idleOh right.
What does it idle at ?
Dont run without it. Tryed it and just stalls engine
Will have to get that checked then.You beat me to it!
It's fly by so it's been mapped with an air leak!
So when you stop the leak there's no air flowing past the motorized bodie?
Its still dropping boost started doing it again i thought i had fixed it so going to test lines tomorrow
if it wont idle without the pipe, it's sucking air in thorugh the carbon canister, probably blown a 1-way valve inside that and that's your leak. Your map will be well out if it was like that when it was done
Dont think it has a one way valve on that line or in canister at all.Danny if you look at the pipe that came off mine you see Bbpt had a one way valve installed.
Mybe the carbon canistor does not have a very good/or no one way valve?
Will have to make sure everything is spot on and check it. What could cause a boost drop other than the pipes???
Gets to 1.1 then drops to 0.6What boost does it get to or hold?
ye its got a controller on it at the mine a manual one. It was mapped for 0.6 but was checked yesterday an was fine to be at 1 bar.So your using a boost controller then?
But what is the ecu map set to?
Mine was 0.6bar when I did some fiddling tho it went to 0.8bar then just shut off throttle for a moment
The brake servo line is standard k-tec dont change them. Iv tested for boost leaks and come up with no leaks. If you unplug one injector the car runs fine lol just found that outHave you fitted a 1 way valve in the brake servo line too?
Remember the servo and cabon canister would never see pressure above atmospheric on a stock car, bobby basics mate. You need to sort all these things properly and get it re-mapped.
A proper pressure test will show you the problem spots, if you dont sort these you will keep getting the same probems over and over gain, the length of pipe used isn't going to make any difference if everythings as it should be.
The brake servo line is standard k-tec dont change them. Iv tested for boost leaks and come up with no leaks. If you unplug one injector the car runs fine lol just found that out![]()
ye there is on the standard one, not driving it no i was on drive. Not trying to achieve anything i was taking them off to see if they were running fine on idle.eh?
so there is no one way valve on the servo line?
you unplug one injector and it runs fine at idle? or are you driving it? i'm not sure what you're trying to achieve by unplugging injectors?
Finaly sorted it changes some bits around at the min it runs perfect![]()
