Twang/Crack When Turning
MrBlonde
Cheers mate.
A new rack (assuming I could even get hold of one!) comes out at £676. I'd rather fancy my chances on a couple of bolts being replaced first! :smiley:
I just bought a 2nd hand one mate the time & also fitted uprated bushes while it was off for peace of mind.Should of done the bolts to at the time but didnt think.
Chrisgti6
  Too many
Not a Clio but I was having a similar noise from my Mini (see my thread for full details) but it ended up being internal to the rack and solved with a £30 2nd hand one.
So while fingers crossed it's the rack bolts, it has potential to be something more still.
Darren S
I think I might just bite the bullet and get an aftermarket replacement rack. KTEC are quoting £255+VAT and while that's not particularly cheap - it's a hell of a sight cheaper than the ultra-elusive Renault branded item.
If the rack wasn't so labour intensive to get to and replace - I think I'd wing it and try the bushes & bolts replacement first. But forking out a wad for labour when there's zero guarantee of fixing the issue, I'm kind of resigning myself to lubing-up and paying to get it replaced.
Fair dues to the 182 - nearly 13 years on and 150k+ miles. Things naturally wear out over time, I guess.
MrBlonde
Changing the rack was a nightmare of a job that me & @Dr Jekyll did,even tho we was on a two poster ramp.The main problem we had was the actual pas pipe!.Such a long stressful day
Keep us updated on the out come mate & what choice you choose to do,may be worth changing the bolts to even if you get rack done,only a couple quid each & get it done all in one hit.
  PH2 172
Shaftec supply an exchange rack, I`m not sure on current price, but was quoted £180 ish with vat a couple of years ago.
Other alternatives are a good used one from CS, or take the opportunity to go for an EPAS conversion.
Darren S
Thanks for that. Why is this one part of the Clios so vague in terms of manufacturers, part numbers and pricing?
I would have thought an RS steering rack is exactly that - something identical across all Mk2 Clios - be they phase 1 or 2.
I’d consider the EPAS conversion more perhaps, if I used it on track.
  PH2 172
I cannot confirm PH1, but all ph2 172 & 182 have the SMI hydraulic power rack.
https://www.cliosport.net/threads/steering-rack-manufacturer-indentification.659212/
