Urgent help!!! Removing front bumper
Car  not a clio anymore
Hi all,
I am in the process of removing my front bumper but I am stuck!!!
I have removed the wheel lining (or whatever they are called), the 2 bolts on each side (near the wheel), the 2 bolts underneath, the 2 screws in the engine compartment (for the front grill).
It seems all okay and ready to remove except it looks stuck just under the lights on both sides!
just give it a good pull - be careful with the headlight washer pipes. Make sure the s**t shields are undone on both sides
Thanks. That was the only problem.
There are like 3 bump that act as clips, 2 were easy and the last one was really hard. 1 person pulling and one person using a srewdriver inside did it in the end.
In fact, after removing everything besides this, we realised that we could have done just one side to get access to the washer jet (which was the purpose of the work).
Next time will be easier!
Thanks for the reply.
washer jet pipes are located on the passenger side behind the front bumper... but you now know this...:o
