warped brake discs
  Clio 200
I believe i have managed to warp the n/s/f brake disc - braking from high speeds there is a vibrating coming through the pedal/wheel.Still plenty of pad left so i know thats not the fault. any ideas?
if that is the case will it be ok to use on short journeys until the new discs/pads come through.
and finally lol is it best to stick with standard discs/pads or after markets?
cheers
  C-VXR, T8 Map 220BHP
you will be fine to drove on it.
i found that O.E parts lasted no longer than cheaper aftermarket ones from places like GSF. i never got more than 20K out of a set of front discs.
  Clio 200
ta for the quick reply,
a take it that the disc will be slightly warped then?
will look into aftermarkets i think.
  Weeman sucks ****
yeah sounds warped to me. i did the same from a ring trip the other year after 14 laps in a day, lol.
should be fine to drive on but you'll get bl00dy annoyed with the rattling. plus i'd imagine the vibrations won't be good long term.
  Clio 200
thanks matey
no intentions to drive on it for any length of time going to order the new discs and pads in the next few days
