Washer pumps. Are they the same?
  Ph2 172
As above really.
I need a new headlight washer pump but can't find one cheap. Are the headlight washer pumps the same as the windscreen ones?
Also, while I think about it. I have to take the wiper arm off obviously. The nut has sheared off. I have a wiper removal tool and was going to araldite it back on after...sound possible? Any better ideas?
sbridgey
  disco 4, 182, Meglio
washer pumps are the same, i would bother replacing if its for the headlight washers though.
sbridgey
No the pumps are the same, i know because i swapped them over as the windscreen jets werent working but the headlights were.
  Ph2 172
Thanks. I'll have a look about then.
I wouldn't bother with them but I'm getting bit annoyed knowing they should be there and work!
Also the new MOTs it's a bit of a gray area.
davo172
  TCR'd 172
^^^^^ THIS is correct I have done the same and without wiper pullers its a PAIN IN THE ARSE JOB !!!!
