water injection turbo and n20?
stevo172-RWD
Car  clio 172 rwd
can somebody tell me is it possible to run water injection(in my 172turbo)
with nitrous at the same time?
i know il need a wet kit with the nitrous.
also which nitrous solution is best?
fogger system or direct port?
i have thought about taping into the inlet manifold.
any ideas/advice?
like everybody says theres a limit on how quick you can go with these.
i wanna do it in style!
also want it to last! no bodging cheap shite
the hardest and most expensive object to overcome is the shitty gearbox lol
bin ok so far tho
are you getting detonation? only use water injection if you are also as chris says no point running them together
if you fit nos the car will go forward and the gearbox will go backwards i'd wait steve until someone decides to do something about the crappy box, i've got mine sorted when to change my gbox to find the garage that put my gbox in hadnt even bolted it up the mount! grrr all good now on my way to paying off my credit card :) turbo next year :)
