So I got the brakes done tonight, started with a few pictures then had no battery
Anyway...
Started with the drivers rear side, couldn't get the carrier off the calliper so decided to just remove the whole thing from the hub and do it that way (didn't matter too much on this side as the handbrake cable is snapped off, which will be replaced this weekend).
Quick inspection of the rear pads shows they're getting rather low.
Quick comparison between new and old discs.
Didn't get a complete picture but we all know what a discs with pads and a calliper look like.
Then got on with the fronts. Had nothing but problems getting the discs off so just got on with it. It does appear that along with the grooved and drilled discs on the front it also had EBC Green Stuff pads (can just see the little bit of green on the backing)
This is the condition of the front pads...
Today I drove to work and thought that a pad had vacated the car en route. But actually you'll see that the top of the two pads is NOT the reverse of it, you can actually see the wear on the backing plate near the clips at the top.
And that's where the battery died. Took it out to bed the pads in properly and it took a while but my God they are great. Not even properly bedded in yet and I've also not changed the fluid either as I didn't have time, can't wait to see what they are like when it's done.
