What size are the 10mm plenum bolts?
Hi guys what size are the 10mm plenum bolts changed my plugs today and the rear left was missing also plug number 4 was very oily hoping I can go grab one from halfords
Make that 3 bolts needed torqued to 11nm two bolt heads went am I missing somthing here f**king scared to touch it now lucky just heads went to took plenum back off and was able to get grip on them
MarcB
  Too Many
Item No 5
FLGD HEX HD SCREW M6x100-25 8-
7703602272
£0.89 = Vat Each
MarcB
  Too Many
I would buy dealer only but thats just me.
Try B&Q or a hardware store if you just want a bolt.
Will just get what I can from halfords tomorrow then order full set monday am I using the correct 11nm?
Also hoping oil in plug 4 was from recent oil top up anyone have any ideas if I check again and it's still there
MarcB
  Too Many
VVT Seal can also leak.
Worth changing that also if you are in there.
MarcB
  Too Many
The part number is on the bag - 7700106385
Undo the electric connector, Undo bolt and the VVT Solenoid will come out as so -
Then use a hook or small screw driver to bend the seal as it is Rubber & Metal like i have posted before and then pop it out.
I used some oil to lube up the new seal and then tap it into place with a socket thats was the same size so it went in evenly
Cheers sorry didn't spott that think I may need to look for a guide more for dumbys as I don't have a clue where to start on that ha thanks for your help though if there's a link for it from start to finish that may help
