What speakers should I get for Clio 2002?
  Clio black 1.2 16v
I'm new to this forum!
I just brought a clio black 1. 16v 2002.
I own a astra 1.6 16v SXI before clio, I had amazing sound system as I sopent 800+ JL Audio, MTX thunder, Evo sub 1300 watt, so you get the ideal.
I',m not looking to spend any more than 200 just on the speakers. What should I get? What size is the speaker for the clio? 13"?
Look forward to your replies!
  2004 clio 1.4 16v
you could get some
Alpine: SPR-50C - 13cm 100RMS 300W Peak components (front)
Alpine: SPR-50 - 13cm 90RMS 270W Peak coaxials ( rear )
just a tad over £200, but these will need amping to get the full potential.
  ITB BG 182
IF you want some thing that is easy to fit but ok for sound then get some of the Pioneer factory replacements, these have the 5.25" speakers with the tweeters for a direct no hassle replacement, sound ok when amped.
IF you want some thing slightly better, get some Focal 5.25" coaxial speakers, they work nice from the factory headunit and even better when amp'd.
Then if you really want a nice clear sound at high volume that can handle some abuse, then convert to 6.5" speakers for the fronts, get some nice Focal component for £130.
http://www.caraudiodirect.co.uk/foc-ps165-focal-performance-ps165.html
I have the above ones and they are fantastic, best speakers I have heard in a long time.
To cut your door out and convert it takes about 30 minutes with a sharp stanley knife.
  Clio 182
I once Bort some alpine type r components and I was a tad disappointed , altho the alpine type R subs are pretty good !
  2004 clio 1.4 16v
did you amp them ?, i am running type r component n coaxial with a alpine mrx-f65 amp and cda-137bti headunit, they are the best speaker i have heard in along run without distortion.
  Clio 182
Yeah they was running off an old beasty alpine v12 mrv amp , I was disappointed :(
