Wheel allignment? Camber 1 degree out? Coilovers fitted wrong?
Car  A45 AMG 406BHP
Went for my four wheel allignment today.
The front toe he did, and caster
I dont have camber topmounts do he couldn't do it
But
one side camber is -1 degree 41'
the other is. -0 degree 40?
What?
The car drives straight and fine!
The rear camber is fine
but one of the rear toe is very slightly out
Thrust angle is fine!ideas?
When I fitted front coilovers the two big bolts
do you have to move the hub inwards or outwards or makes no difference?
Thanks.
All I saw the bloke do is undo tr ends
he put the gauges on all four wheels.
He advised camber mounts
Gaz golds
I only want standard settings
carnt they use standard bolts to adjust camber settings ( standard)?
They didbt even touch the two big bolts?? Which hold coilover to hub
Standard topmounts brand new!
Ps what is standard camber?
If you pull the hub out at the top you will lessen the camber, but you'll need the tracking setting up again. Did they not even advise you about the difference in camber per side?! Most normal garages won't adjust anything camber wise as these places generally employ idiots.
Standard camber is around .5 degree.
Whereabouts in Leicestershire are you based? I'm not far off ashby and I'm happy to track it and set the camber if your interested? Pm me if you like.
I presume this hole allows camber?
So I can use standard bolts?
Should I take it back and say why adjust camber?
1: I didn't think you could adjust caster on std top mounts?
2: What toe in/out did they do? Adjustment on the tie rods for that IIRC
3: If you've fitted the suspension in the pic above it looks like the top hole is elongated, you can use the OE hub bolt and still gain negative camber
I just slotted the top hole on my coilovers, did some funny calculations and machined them around 1mm towards the car on each side, put them back on, bingo. Perfect Camber.
Do I set it or should they have done it?
Surely they should have!
Can they do it without removing wheels?
thanks!!
I paid for 4 wheel allignment
but discounted due to rears being fixed
Paid 26
There website is in my post above
I guess there are places out there that do it, a job as such, but there are people less well known that have the knowledge to deal with such things. Its who you know, it might be worth taking up Northloopup's offer.
Its 1 thing to set up the geometry but another thing to know the reason why it's that setup and what benefits ( and potential drawbacks) it has
I'll take it back
The guy said the camber was fixed which is a lie
Whats the standard camber? 182 cup?
Is it -0 degrees 40?
