Wheel Spacing on RS wings.....
Car  www.renparts.co.uk
Im fitting a 172 front end to my dynamique, of course spacing the wheels is an issue, im going to require at least 20mm spacers to make it look anywhere near right. What part is it on the 172/182 that sits further out? I figured i could put the wishbone/hub or whatver it is off the 172 on there to space it properly, i have access to these parts very cheaply so cost isn't really an issue. I figured i could get these parts then when it comes to fitting coilys i could use 172 ones. Im probably missing something crucial but i just thought i would see if it was possible. If this all fails and i choose to fit 20mm spacers what will it effect in terms of handling? I understand that its causes premature bearing wear etc and im prepared to deal with that im just worried its going to nacker my handing.
thanks
josh
