Why are Renault bolts made of cheese?
Persiflage
  Clio 172 Phase 2
After 18 years of ownership, fortunately without many issues, I thought I would tackle what should be the simple job of replacing a failed alternator. I should have known better and reflected on my previous experiences working on the 172 … expect the worst :confused:
PKs attaching bumper/wheel arch shields required grinding off ,and i was very lucky to remove the slam panel top bolts in one piece but the bottom fixings required a lump hammer to shift them once id found something that fitted between the heat exchanger and panel. The icing on the cake … alternator top bolt head has sheared off. the nut released without much issue. The bolt on the other hand was corroded solid in the alloy casings to the extent I had no idea whether this was a push through bolt or if it screwed through the casings, result, one sheared bolt. If it was threaded into the casings this was going to be a MAJOR problem :mad:. Fortunately after half hour messing about I’ve managed to drift the offending item out.
FFS Renault have you not heard of Galvanic Corrosion.
hopgop1
I think it comes down to the French mentality when it comes to cars, the Clio 2 in general was made to be a Parisian bumper car, they weren't built to last this long. Only the crazy Brits would keep their old French sheds going for over 15 years :ROFLMAO: . Doesn't mean they're bad cars, Renault just saved money on expensive fixings that would be pointless in their closest market IMO.
Persiflage
  Clio 172 Phase 2
The main connection to the alternator was so tight and corroded despite lots of Freeway I was convinced I would rip the internals our before the nut came loose. Now I can’t figure how to remove the small connector. It seems every connector on the car operates in a different manor. Can somebody confirm this is the type that requires a small screwdriver down the side to unlatch.
Coops Mk1
  Lots of Scrap...
My 250k 18 year old daily falls apart like a dropped Lego model..... regularly tbh 🤪
