will the 1.8 16v valver engine fit in my 2005 clio 1.2 16v
wats the wiring going to be like .. best appraoch to it ? stanalone on my 1.2 loom or ???? the reason im asking is i want around 130bhp + and something different from the norm, im keeping the car so thats not a prob , have a range rover s ma daily lol,. and ive always fncied a valver lump in a newer car
i've done it the other way round... wiring would be fun :D
probably have to use a combination of both looms together to keep the dash working
take a look through the projects section, i'm sure there's a guy who's put an itb'd F7R into a mk2
Fucksake dude, make up your mind, first your turbo-ing your 1.2, then your supercharging it, then your fitting bike carbs to it, and then this. Just decide on one thing and do it!!!!
okies. ive got all the parts to turbo the 1.2 here but im just lookin at options while i can..i still need to sve for managment see. i want to use a megasquirt but i cant find the info to see if the engine uses crank trigger wheel..
which engine? f4r uses a 60-1 on the flywheel, mk1 clio 16v/williams is different
its a 1.2 16valve engine which is bein turbo'd. its a f series engine so id asume its similar ? am i right? how would i be able to find out if not as this is the only peice of info im missing for me to run boost in the 1.2
