ive just upgraded my brakes, wilwood midilites, brembo max discs and ebc greenstuff padsand changed the brake fluid to castrol super response dot 4, i sourced all the parts myself and had the brackets made up and fitted.
i already had goodridge brake hoses but u will need longer ones. on one side at full lock one of the hoses tugs a bit.if u want to save on cost u can just get one longer hose. i changed both sides to the longer hoses.
i was told i might have to get a slightly larger master cylinder with a bigger bore because the brake fluid will need to be pumped further because of the larger calipers. this was to counteract the fact u might have a spongy pedal.
initial reactions on the drive home from the garage (60 mile trip) was the brakes felt the same as standard but with a very spongy pedal
because everything is new it will take 250-300 miles until they bed in , if not more.
took the car out for a little drive today (30 miles) and they felt much much better
more bite and pedal seems to be firming up. im happy but not over the moon just yet.
i cant give much more feedback , but considering the brakes felt a whole lot better today i can only say i think there is a lot more to come from them once they are fully bedded in. ive not done any heavy braking as of yet ill let them settle in first but once ive done a few more miles ill give an update
