Wishbones ect
Hi all
In the process of replacing the wishbones, ball joints, rack ends and arb bushes on the Clio.
It quite clearly hasn't been looked after as all the bolts are rusted solid and some have snapped trying to get them off :(
Is it possible to buy the following separate from the parts?
4x ball joint bolts
2x ball joint pinch bolts
4x wishbone bolts the attach it to the subframe
Scott
I'm looking at getting them off eBay, it's only a 1.2 so looking to keep costs down, looking at the listing the wishbones come with ball joints and bolts so I'm just after the pinch bolts and wishbone bolts
Scott
Did you ever find out the dimensions of the bolts, nuts and washers required for each of the four corners? as I'm looking to refresh the front suspension on my 1.2 but can't find the information on the bolts needed to connect the wishbones to the subframe.
thanks
