Wrong springs fitted
Car  Audi A6 Avant S-Line
Hi
I bought a set of lowering springs off ebay (apex) but when they arrived i noticed they were for a 05- clio whereas mine is an 03, I didn't think they would be much difference so I got the garage to fit them, they are ok but haved raised my car by about 10-20mm and they are rubbing off something every pothole/speedhump i go over. would it be ok to continue driving like this until I can afford the correct springs
Does anyone want to swap mk3 40mm springs for mk2ph2 springs
DazJ
Probably isn't a good idea to continue driving it with the incorrect springs fitted, just incase. You should get your original ones put back on, and maybe sell those and then get some new ones.
Obviously something wrong if they are rubbing.
hmm, just the only reason why i wanted it lowered was because my 2 front springs had snapped
the cars been raised?! if theyre for a mk2 then they should fit no worries, and lower the car, they did make mk2s past 05, (ph3 & ph4)
if theyre for a mk3 then id be worried,
either way theyre either the wrong springs, or theyve not been fitted properly, i would try to avoid driving in any case, can you not jack the car up and have a look??
I've got standard 182 springs if you want to make me an offer, pm me?
back street garage, I would sell them for £60 but I would need to put new ones on and I can't afford new ones until I sell the old ones so it's a bit complicated
