Darren S
Got one of those 360 controllers plugged in (the PC is currently on it's third day of therapy and medication to cope) - but I'm stuck on the following bit. A pissing easy one at that!
So I need to press LB to start the jump or else I just fall off/never make it to the other side. But the LT prompt above I've tried in so many ways. Straight after the jump, almost on the ground on the other side (as mentioned in the prompt) and several ways inbetween.
Do you have to be looking in a certain way for it to work? I land ok-ish on the other side but the game says I failed the test.
Cheers,
D.
Cheers,
D.
