SharkyUK
		Unlucky mate
 Hopefully things will calm down soon and you'll get some free time to work on it and get it sorted.
			I should have asked at the end of the other post, do you think the high ambient/track temps were a contributing factor?
Unlucky mateHopefully things will calm down soon and you'll get some free time to work on it and get it sorted.
How do you plan on moving all your cars to the new house? Lol
Ive got the head off now so I know what bits to order etc, but I will leave it till winter to even try and do the work now, as Ive got so much renovation work on the house and so many other cars that are more urgent to crack on with. Oh plus we just bought an RB yesteday which no doubt will take some of the precious little time I have too. Getting a bit silly clio wise now we have:
Williams powered Mk1
Ph1 turbo
Ph2 RS2
RB 182
whoopsy!
So the turbos back for next season then![]()
hopefully will get alot of track time with you guys this next year
Which ones getting the hubs then chip? Turbo or Lesley's?
Ah fair enough. We did a pair of Williams hubs in the group buy as well funnily enough.Not sure yet. Probably swap it about a bit between them and might try on the mk1 too.
I run the 172 turbo, the 182 and the mk1 all on 172 suspension setups so it's all interchangeable between them.Ah fair enough. We did a pair of Williams hubs in the group buy as well funnily enough.
After seeing the size of the Williams/16valver hubs I don't blame you tbh mate. They're tiny in comparison, as I'm sure you are aware!I run the 172 turbo, the 182 and the mk1 all on 172 suspension setups so it's all interchangeable between them.
Yeah the weight reduction did enter into my mind when I saw them. Shame the shafts are a pita really.Still normally strong enough and are lighter so in some ways better. Main problem though is the shafts. Williams ones are expensive and hard to find and valver ones are shorter than I require. Where as 172 ones are cheap and available readily both new and second hand.
