Project 432 - Mk1 Track Car
  Clio Williams 3 K24
Hi all.
Finally after over a years worth of the car being sat, SORN, feeling sorry for itself being in a poor state due to me having to travel with work in something 'normal' and moving house a lot.
It is now back!
Some of you may remember the car from my old thread on Clio16valver.co.uk quite some time back but I didn't get round to making a thread on here before now.
http://www.clio16valver.co.uk/forum/viewtopic.php?f=6&t=48130
Since all of that it had been my daily which didn't give me chance to sort things that needed sorting.
Now I have a house with a garage and a daily car, it will get the attention it has desperately needed.
It once used to look like this before it was taken off the road:
French Car show 2012 spec with ATPower throttle body. V6 airbox was re-fitted after the show.
Earlier on in the year me and my good friend Ryan at Race Performance & Transport transported the Clio from my home town of Worksop to Coventry using his single car trailer.
As you can see the Clio was in a 'bit' of a rough state.
Since then the Clio has just been sat in the garage waiting to be worked on.
The Plan
Restore the shell back to a 'rust free condition' with:
- New bonnet (got)
- New doors (got)
- New passenger wing (fed up with the 'drift stitching') (got)
- New rear outer and inner arches
- New front inner arch sections
- New inner sill sections
- New floor sections
- Reconditioned subframe
- Fully seam weld the shell
Get hold of:
- Polycarb windows for the rear quarters and rear screen
- Cage from Custom cages, basic cage with additional members to front turrets and single (non-crossed) door bars (Group A configuration to keep weight down, ease of access and ability to use the window winder)
- Manual poverty spec window winders
- Non-sunroof skin
- Flocked top dash
Fit all the other parts I have accumulated over time
Powdercoat my not-so-white wheels back to white and fit my set of A038's
The overall idea with this is to make it as you would expect to buy it from a dealership with a decent finish, no rough edges, whilst maintaining usability and reliability on the road and track.
Oh, and enjoy the thing!
Josh
  Clio Williams 3 K24
09/06/2014
Not much of an update on the progress on the Clio - just a bit of a prep of the working space around it. But still thought I'd get some pictures of it and get in the daily RT
The daily and not-so-daily...
Also mounted my pin board to help organise and manage the project
More updates coming soon.
Cheers for looking.
Josh
  Clio Williams 3 K24
Seeing as I haven't updated the thread in quite some time, it is about time to do it.
16/08/2014
The beginning of the front end strip-down.
24/08/2014
Further strip-down of suspension.
14/09/2014
Subframe removed and dropped the engine.
  Clio Williams 3 K24
Further updates continued...
05/10/2014
Made a start on the interior strip-down.
Nice bit of rot...
12/10/2014
Made a start on the brakes too.
23/10/2014
Things were getting a bit dark in the garage so I wired some stip lights to a 3 pin plug. Winner.
Cheers for looking.
  Clio Williams 3 K24
Only just realised that I hadn't worked on the car for a very long time - basically the complete winter season and it was very sporadic with little direction...
Here is a bit more progress.
11/05/2015
Started chopping the rotten areas away after taking delivery of my new R-Tech welder.
To uncover more lovely rot...
Spare bits.
Welded in seat rail removal.
21/06/2015
Shifted the engine out of the way so that the shell can be moved outside for better working access.
Out in the open.
30/06/2015
Knocked up a cardboard template to make sure both rear arches turn out the same as each other.
05/07/2015
Ready for the chop.
11/08/2015
Chopped.
To uncover a whole world of rot.
More spare bits.
Cheers.
  Clio Williams 3 K24
15/08/2015
Got properly stuck into re-modelling the inner arch using poverty spec repair panels. By no means are they a direct fit for a 16v/Williams. These are Klokkerholm items and are good quality.
If you want to replicate the 16v/Williams rear arches using these panels then you will have to use the panel in sections.
Chopping back to the decent material.
20/08/2015
Started offering up the poverty spec sills to the original 16v/Williams inner arch and I am left with this amount of gap.
The plan is to keep the standard 16v/Williams profiles as much as possible as I am fussy about stuff like that. So I will have to extend the sills to fit around that profile.
Offered up the second part of the inner arch.
Cheers.
  Clio Williams 3 K24
08/09/2015
I knocked together one of my trolleys which the shell will sit on in the garage for ease of movement.
18/09/2015
Started to crack on with the inner arch again. This, again, is not by any means a direct fitment as plenty of marking up and testing had to be done to get this in the right position and shape.
The slits cut into the panel helped when manipulating the panel to join the 16v inner arch and to achieve the correct shape.
Just need to knock up a plate to sit in the window at the base of the arch and one for the gap between the repair panels.
The paint is just weld through primer to give it that extra bit of protection during work and resting times.
The welds will then be ground back, primer removed and seam sealed once I have welded everything.
More updates will follow.
Cheers for looking.
  Clio Williams 3 K24
20/09/2015
Small update.
Spent 1.5 hours on the car and added further material to the rear arch.
Cheers for looking.
Josh
  renault clio mk1
Wanting to do the exact same only thing is mines a sh*it 1.2 hopefully a 16v front end coming soon if any parts available please do let me know cheers
  Clio Williams 3 K24
Not sure if I will have any parts available but I will be selling the 172 engine and JB3 (valver) box soon for something rather different in its place :tonguewink:
  renault clio 1.8 16v
Project looks good mate I'm going through the same right now, look forward to updates. is the 172 engine plug and play? and how much are you after for it?
  Clio Williams 3 K24
Cheers!
It's not plug and play as you have to modify the engine loom to fit the valver plug, your exhaust either to take the standard 172 cat/decat, get an ECU which has to be virginised and the immobiliser bypassed and modify the inlet to relocate the coil pack to sit away from the rain catcher.
I can sell you a plug and play setup; engine, engine harness for a ph2 Clio 16v, decat, cat, exhaust manifold, ECU, ph1 inlet and throttle body (cable type). Pm me if you are interested.
Josh
  Clio Williams 3 K24
Bit more of an update:
25/09/2015
Finished adding material into the rear inner arch.
Ground the welds back.
Sealed the welded areas. Might not be the prettiest sealing but if it stops water ingress and rot then I'm happy.
27/09/2015
Started chopping away the drivers sill and the rust in the inner sill.
Rear section if the inner sill is prepped and painted with weld through primer ready for the new plate to go in.
Cheers for looking.
Josh
  Clio 172
Back then most expensive one I saw was £1500 and it was mint, the one I bought was really clean, then I bought some oz super t's for £80 haha student living
  Clio Williams 3 K24
Haha! Student funding is the best. I practically built the car whilst being a student! Shame you cant really say you can get hold of a clean and tidy valver any more.
Josh
  Clio Williams 3 K24
Bit more of an overdue update:
09/10/2015
12/10/2015
14/10/2015
16/10/2015
18/10/2015
02/11/2015
Since the weather has been getting worse and I was getting to the point of it stopping play, the Clio ended up back in the garage.
Also made it look like a car a bit more. Only a bit...
05/11/2015
Started chopping away at the drivers footwell/A-pillar flooring.
07/11/2015
Smaller update but significant still - the first step of parts progress/gathering for the Clio - Renault Safrane front hubs (same as the Clio cup racer ones).
Hope to have more frequent updates!
Cheers for looking.
Josh
bauderline
  Dimma Clio No 31
Thanks for uploading your progress photos! I am currently restoring Clio Dimma 31, I was concerned about cutting away the rotten inner sill around the seat rails until I had the rest of it welded up as they are the only things attaching the inner to the floor pan at the moment. I see you found a novel solution.... Same difference I guess ;)
What are the specs on the Safrane hubs ? Do they allow for bigger discs / caliper upgrade. I was thinking about fitting 172 hubs/discs/calipers as by all accounts they are more than sufficient in terms of stoppage.
