Trackday pads
I've got RC5+ in the Clio, holy s**t (I'm new to track days, I only have 4 days experience) they are good. Totally f**ked my braking references up for Oulton because I was used to braking a tad earlier on the standard Brembo's.
I went for DS2500 in the end as I got some with around 80% meat left on them for £60 posted.
For cadwell they were epic, didn't notice any fade on the total of 2 laps I actually ended up doing... :blush::blush::blush::blush:
because
20160115_125003 by dann2707, on Flickr
Fair enough, seen too many set of studs coming lose for my liking now.
Screw in studs only come loose if fitted incorrectly, its hugely important to make sure both hub and stud are 100% free of grime and grease. I run a tap through each thread spraying brake cleaner to get them fully clean, then use a high quality stud lock like Loctite to make sure they never come loose.
