BG 182 daily
Here's a picture of when I 1st purchased the car to how it is now, still unfinished!
Can't beat a nice bit of beading!
Early night for me! I've Got a nice drive to clioturbo in the morning.
Is that toast instead of fried bread!? Boo!
Yep it is! Tried making it healthy as possible as I'm meant to be on my diet :(
just arrived home from clioturbo after having the following done:
Cam belt
Dephaser
Aux belt
Oil and filter
Gear box oil change
Polly bush engine mount
197 cams fitted and timed.
Crap drive home as i can't use hard acceleration Until the cars been remapped but pleased with the work carried out and Andy seemed a sound guy!
When and who's mapping it mate?
Going down to efi on Wednesday luckily, it's idiling badly and cuts out at junctions haha made a interesting drive home! Looking forward to seeing how it drives after the map
Just a quick clean before the trip to efi tomorrow
Just come back from having a piece of stainless pipe welded on to the end of the cat to create a sleeve to meet the centre box instead of a olive joint! As tight as I could get it there was still a blow! New gasket fitted also so hopefully I have no loud whistle under acceleration!
Just arrived at efi for the remapping! Hopefully these 3 hours fly!
Just got back! She made 10 ponies more with the cams fitted! The power is a lot smoother now
Just had the drivers side cv boot replaced again for the 3rd time! Took it off and it looked to have melted so I'm guessing 4 hours on the dyno may have caused this!
What cv boots have you been using? I replaced my genuine one with a stretchy one and it wore a hole in it within a couple of hundred miles. Replaced it again with the same one but cut it down slightly and it's been fine since.
Not sure on brand was a green and yellow box? Mechanic couldn't get a genuine one so settled for a different one the make began with L? so I'll see how it goes, it did look perished so I wonder if the heat from the dyno caused it? I felt my tyres and there were rather hot and tacky
This is how it's sounding now wth the cams fitted and idling at 1k. 10 times louder in person! The tips were shiny on weds!!
Clios having a new drivers drive shaft fitted tomorrow see if that stops it from chewing cv boots! So I've got a nice courtesy car for tomorrow! Sorry for the dark picture [emoji3]
Not posted for awhile as nothing new has changed, today changed the oil and filter, bought these to speed up the process
Replaced the front shocks with genuine Renault, last time I looked the passenger side was knackered! Have a guess which is the passenger shock! Both were compressed in!
New rear shocks and polly mounts arrived ready for fitting on Saturday [emoji41]
The cars having a well deserved Detail day as she's needed!
Using some new and old products that I have
Clay baring done now ready for the polish/sealant/wax
All sealed up now [emoji3] started to get fed up towards the end!
