Which discs/pads for Willwood 4 pots?
Car  Clio 182
I'm about to buy some Willwood 4 pot calipers from someone on here but he's not sure what discs/pads they take. He thinks they might be Megane discs, is anyone else able to shed any light on the discs/pads that I'll need come replacement time?
Thanks,
James
JamSport making a kit using wilwoods and they sell the discs. Just check the sizes.
I'm running their 2 piece discs using AP Racing rotors
I can sort discs and pads for those aswel James, let me know the dimensions and I'll know which discs. Pads on the shelf
Just sent @Nathan181 some Ferodo Racing pads and 8 groove AP Racing rotors
Can you get disc that fit the jamsport wilwood kit that they sell?
Yes , I've just sent Nathan the AP rotors for his jamsport kit bells .
I can also supply the vented 1 piece discs they use but will need redrilling/modifying to fit as they run an Avensis disc (got these before so know they correct ones)
Thanks for you reply that's good to know:up:Can you get the bells as well or just specifically the pads reason being I purchased a set of calipers but really would like to run two piece disc at the front if they will fit under 15" wheels?.SJ.
no worries, not been asked about the bells before tbh but don't think they'd be an off the shelf part. If you can get hold of one I'm sure someone would be able to make them up
I can sort the pads no problem , few options depending on use
