BG 182 daily
Little update, I've made a list of the things I'm still needing to get to finish the Clio to how I want it for now...
I've replaced the front and rear shocks, springs and top mounts, I'm wanting to do the wishbones track rods etc with pollybush inserts! But I think a pms shifter will come first I keep eyeing them up!
That's the shortest ghey boy list I've ever seen, and you definitely need to add get an exhaust to it.
Exhaust is going no where! It's the heart of the car! Makes it special as it's probably the loudest Clio around [emoji3]
I'd recommend you order your seats ASAP... Corbeau have a waiting list for their clubsports. I've just taken in my deposit for my two seats and they're in the process of making the next batch for dispatch.
They should be shipping at the beginning of April.. I'll get mine first as I live 3 minutes from them :smile::stig:
Thanks for the heads up! May have to look at those first then instead of the pms shifter
Small update nothing to interesting! I've bought a spare set of front upper and lower grills to spray black.
Grills now sanded and wiped down with anti static cleaner ready for paint next week at work.
Need to do this (I probably won't) to my upper grill. Solution finish is good, but not really a solution, well for a few weeks anyway lol
I kept putting it off for a few months but I'm having the car detailed next weekend so I'm hoping to have them painted and swapped over before she's all cleaned up
Well productive weekend! Washed my car!! Noticed the front number plate wasn't fully stuck so peeled it off, previous owner as used some sticky gum! What a bloody mess! I'm the process I managed to bend the number plate as it was only made from Ali!
So New set ordered from fancy plates with a smaller front to fit the recess!
The next thing to put me in a better mood! The bloody drivers side window had dropped! I'm guessing knackered regulator so going to find a replacement asap! I've managed to break part of the window seal that sits in between the window and the door card! So something else I need to source now!!
Least I'll be cheered up next weekend! She's booked in for a full machine detail with a ceramic coating applied! And the headlights polishing and sealed! [emoji13] sooo glad payday is Tuesday!!
How much is that costing and what size for front number plate
it was £130 for the detail in and out and headlights restoring, then I added glass protection and ceramic coating that lasts upto 30k miles, it's costing £200 now
You should've gone proplates mate! It too late to cancel your order?
How much for the pair? £25 delivered with the cs free shipping code at proplates.
£36 delivered it's not to bad and i just went for standard lettering with a simple border! The ones on the car are press plated and I'm not that keen on them
Not too bad then :D Yeah, im not a fan of press plates ones either. Mine are just completely plain with standard lettering.
Picked up the paint tonight ready to spray my grills sometime this week at work!
Let me know how it goes, I need to do mine really.
Will do! Hopefully I'll have them sprayed today and fitted for the weekend! I want to try and get my original grills out without breaking anything so I repaint those aswell [emoji3]
New number plates arrived today from fancy plates, I went for the 520x90 on the front as the original over Hanged!
Is the front plate a perfect fit in the recess at 90mm then?
I can't believe I fixed those headlamps for you to ruin them with orange bulbs ffs[emoji22]
It's slightly smaller I think 94is the perfect fit? I'm being different haha! I need to change all the bulbs tbh going to do it when I swap the grills over! Need to tart her up for newby hall
Jus dropped the car off for a full detail with headlight restoration! Can't wait for the results on Sunday!!
Well collected the car yesterday evening and I'm really impressed with the results! The paint was showing it's age and previous owners hadn't looked after the paint. Still some minor marks but no more swirl marks [emoji3]
If anyone's in the Yorkshire area get in touch with dtaylor car care on Facebook
