Black 182 Track Toy...
Great read that.
I note you've mentioned trailer license a few times. With what the Clio weighs now, dependant on your tow vehicle, you could probably get a trailer now and not need to do your license.
I've got a Woodford 400KG trailer with a 1200KG car. I pull it with a MK7 Golf GTD so i imagine your Golf R would pull it too. It does however depends on the MAM of the car and the trailer combined.
Cracking read though!
Thanks mate! My towing vehicle would be my work van as I can store loads of tools/wheels but I would defiantly be over 3.5 tonne. I found a place near me that do a full days training and a test for £400 so might just do that.
Looks mega in that last picture!
Thanks. :up:
This is looking stunning and so meannnnnnnn :smile: nice one
All black for the win :cool:
Off we go. Next step has finally begun
Hope it's alright for you mate. Wasn't sure on colour at first but looks good against the black.
You need to get it finished for the Thruxton meet later this year since you're only 5 minutes away from the track!
Anyone else looking for a cage half or full, drop me a message :wink:
Saw your post on Facebook earlier too mate, out of curiosity what have done to bypass the immobiliser?
Looks epic! Got any pics of the uch/fusebox? Need to relocate/secure mine now Ive had my front cage done.
Right....
Donington today. First time on the circuit and its awesome. Its the first track i've driven where elevation plays a massive part. Loved the whole day. There was lots of fast clio's to play cat and mouse with and @mattsouthall of course. Started off very wet do decided to use the Michelin's and then span at Coppice. Too fast too wet and the wrong angle and knew as soon as I hit the apex the back was going to overtake the front. :tongueclosed: All fine though. Dried out in the afternoon and got the R888R's on and could go much faster. Def will be going back. Heres some pics...
New spec list...
Engine/Gearbox
Ktec Induction Kit
Pure Motorsport Exhaust and Decat
Pure Motorsport A/C Delete
Pure Motorsport Shifter Kit
Suspension/Running Gear
Installed BC Racing Coilovers & Solid Adjustable Top Mounts
Installed Whiteline RARB
Full Suspension/Roll Bar/Dog Bone Polybushed
Axle Spacers Behind and Hubcentric Infront
Camber Bolts/Shims
Hub Stud Conversion
2 Sets of 15" 2118's. R888R's & PilotSport3's
Traction Control/ABS/Steering Lock Delete.
Brembo HC disks, DS1.11 Pads, Braided lines and High Temp Fluid.
Exterior
Ktec Headlight Blanks
TRS Carbon Fiber Roof Vent
CMComposite Splitter
CMComposite Canards
CMComposite Brake Ducts
RickyEvans Heated Screen
Interior
Removed Trim/Loom/Sound Deadening/Heater Matrix & Fans
Dash Top Flocked with CMComposite Dashpod
Sparco Evo LF Buckets
Scroth 6 Point Harness
OMP Steering Wheel/Momo Boss
Full cage by Tom Johnson
Things to do before next track day....
Rear disk bolt thread has ruined so need so change that. No idea why that's happened and its the second time! Any ideas?
Fit DS1.11 Pads
Renew Fluid/New Bleed Nipples/Bleed brakes.
Finish Fitting Brake Ducts
Fit Aero Catches. Got black flagged at Donington for the catch failing and it coming up (secondary catch caught it).
Long term plans
Buy a trailer (first on the list)
Gripper Diff
Fiberglass Donnet/Doors/Tailgate
Plastic Windows.
Map at EFI
Lower Subframes
Think that's it :smilingimp: And shes home....
I to would like to understand how this was done as I'm just about to put in the MSA electrical cut out equipment and if fairly easy would like to get this done as well. Great build btw
I asked my mechanic and now I've seen it in person I understand it a bit more. For the moment we had kept the key to work the immobiliser/alarm/central locking for security. Turning the key now does nothing it just needs the key in, the ignition is controlled by the switch. When I get round to fibreglass doors the whole lot will be removed and it will be controlled purely by the switch. As to how it's actually done I have no idea. Hope that helps.
Ahh that makes sense, I may have to make up something to hold the chip and ring then if I decide to lose the ignition barrel setup
Thanks mate
Today's efforts. New rear disk and studs after I killed them on the last outing. 😅
New pads. 4 track days those 2500's have done. Replaced with ds1.11's
As I got black flagged at Dony for the bonnet latch failing twice :grimacing: thought I would get some cheap pin latches from DT. Will get replaced with nice carbon aero catches when I go fibreglass but these will do till then
Got new bumper ties as mine has perished and should bleed the brakes as they haven't been done in 6 months but got new nipples on the way so no point in doing it now. Done a fluid/bolt check and we are ready for the next outing. :cool:
Couple of snaps from brands today...
Car behaved itself, really enjoyed the circuit and had a blast. Think I've nackered one of the front disks as I'm getting a lot of juddering/vibration under breaking. So I've ordered some new disks and will go from there. Nice to be taking the car out and enjoying it rather than looking at it sat in the garage.
